Wanted--D-14 2nd-3rd shift fork
Dave(Billings,MT)
08-10-2007 14:02:06
Has anyone got a good used 2nd-3rd shift fork for my D-14? Maybe even a NOS one?? Jammed in 3rd, took off the shifter assy to find the fork was broke, luckily the broken piece was still where I could reach it. Thanks in advance. FYI-these are not available from AGCO.
Dave(Billings,MT)
08-10-2007 21:08:48
 Re: Wanted--D-14 2nd-3rd shift fork in reply to Dave(Billings,MT), 08-10-2007 14:02:06
The part # that AGCO gave me is 702 25840. Thanks for checking. I had thought about welding it however the end is worn and would have to be built up. Would rather have a different one if possible. Thanks again for all the help.
den/illinois
08-11-2007 12:25:38
 Re: Wanted--D-14 2nd-3rd shift fork in reply to Dave(Billings,MT), 08-10-2007 21:08:48
Dave, Sorry but I do not have a new one. Den
Eldon (WA)
08-10-2007 21:19:37
Dave for the old part numbers, just take the "70" off the front of the number. Doing that, from my Master Index I get that a CA, D10, D12, D14 and ED40 are all use #225840. I have a parts CA here, so if you can describe which fork it is I should have a used one.
den/illinois
08-10-2007 16:39:56
I can check my stock of nos parts if you hae a part #. That's the only way I can tell is with the part #.
Den
Will Herring
08-10-2007 14:46:24
If all else fails, is it possible for you to weld the broken piece back on the fork? third party image
