AC C pilot Bearing
Jim Hunter
08-09-2007 12:40:35
I am replacing the pilot bearing on My AC C I think the cause for failure was no lubrication, the oil wick on the crankshaft looks pretty short. Can I replace the bearing with a sealed bearing that doesn�t have to be lubricated? If not can I replace the wick without taking the engine apart and where would I get a wick?
Kevin Meier
08-09-2007 19:09:57
 Re: AC C pilot Bearing in reply to Jim Hunter, 08-09-2007 12:40:35
I have the release bearing in stock if you need one. I also show 2 different sizes of bearing depending on which clutch you have in your C.
steve(ill)
08-09-2007 18:58:27
you are talking about the throwout bearing, and yes, it can be a sealed unit.
Jim Hunter
08-09-2007 18:27:15
Thanks for setting me straight. What I meant was the release bearing. Didn�t know that the wick was for the pilot bushing. I guess it was just time for the release bearing to go out.
chalmersbob
08-09-2007 18:00:32
it is a bushing. if oil wick is too long it brings too much oil to the bushing and can cause a problem by getting oil on the clutch. bob
Dick L
08-09-2007 16:42:02
I suppose you could if you would machine the flywheel to except it. The pilot bearing is a bushing.
old
08-09-2007 15:15:56
If I rememeber right the one on my C was a sealed prelubed bearing. Been 2 years since I was into it
