WD45 info
Richiewis
08-09-2007 07:11:13
Going to look at 1953 WD45 WFE w/all hydraulic loader,6ft woods mower,3pt,new rear tires and rims.Owner says it runs good.Needs exhaust manifold.Asking 2500.Any thoughts if price is in the ballpark? Tractor is in Central Wis.Thnks in advance
JMS/MN
08-09-2007 09:16:31
 Re: WD45 info in reply to Richiewis, 08-09-2007 07:11:13
Check the serial number, WD45 is 146,607 and higher.
old
08-09-2007 08:38:50
AH but is it a WD45 not a WD. Theres lots of WDs out there sold as WD45 and they are 2 different models but to most people they are the same unless you know what to look at on them. The WD engine has a plate that bolts on to the right side of the engine and the WD45 doesn't have that plate. Also the WD45 has a curved shifter and only the very late WDs have that type of shifter. Now on the price I have seen just a plain jane WD go for more then $2500 at auction but I have also seen plain jane WD/WD45s go for less then $1000 at auction. So yep price is in the ball park. Reason I said some thing about makeing sure what model it is is that its common for people to sell them and not know what it is
John (MO)
08-09-2007 08:20:47
If all is as they say, AND the transmission is good, then it is a good deal. There is fair money tied up in the rear wheels and tires. If it really is an all hydraulic loader then there is most likely a second hydraulic pump which adds good value. A good Woods mower isn"t real cheap. Just make sure the tractor transmission is good, or you could be looking at a thousand or more in repairs.
Texas Denny
08-09-2007 07:31:32
The all hydaulic loader adds to value as does the shredder. Shredder is probably worth $400 and Loader worth $600 to $700. That makes the tractor about $1500. With a WFE, that is a good deal. I'd jump on it.
