BobHnwOh, question on your wd45 3 pt.
Mike in Ohio
08-08-2007 19:03:54
Awhile ago you posted a picture of your 3pt conversion on your wd45.We did something very similar on ours but your mount for the top link is much better than ours.Is it mounted using longer bolts through the differential cover, and did you use any kind of spacer? How thick was the plate bolted to the tractor, and what size angle iron did you use? Thanks alot. Mike
BobHnwOh
08-09-2007 04:14:07
 Re: BobHnwOh, question on your wd45 3 pt. in reply to Mike in Ohio, 08-08-2007 19:03:54
Mike,I used 3/8 thick plate and 2 inch leg angle,4 bolts are 3/8 X 2 1/2,spacers were cut from 1/2 black water pipe,hth,Bob. third party image
Mike in Ohio
08-09-2007 18:01:13
 Re: BobHnwOh, question on your wd45 3 pt. in reply to BobHnwOh, 08-09-2007 04:14:07
Thanks alot Bob, that helps a bunch now I have to root around in the scrap pile for a peice of 3/8 steel. Thanks again, Mike
