WD 45 carb
kurt a. gagnow
08-07-2007 11:24:45
My Dad has a WD 45 The tractor is in very goood shape but it runs bad. you have to keep the choke on to make it run. and it wont go to full thottle. it has that wonderful HOLLY carb! any good ideas other then it must have dirt in it! IT Was already cleaned! THANKS KURT
tim[in]
08-08-2007 12:59:39
 Re: WD 45 carb in reply to kurt a. gagnow, 08-07-2007 11:24:45
Does it run that way hot or cold or both? I need head work on all 3 of my allises and they all burn out around the exhaust ports where the head and manifold meet , but i have not had the full power trouble.all of mine are ms carbs. Mine is ok at cold then when warm needs choked and sometimes will have to stop the bushog and tractor foward travel till it gets power back. That is on my D 17 . Funny little things carbs aint they? lol good luck. Thinking of taking mine to pro rebuilder even thought i had replaced all of the parts and float in mine, just to get it lined out.
CWL
08-08-2007 05:43:47
It's been said before, but make sure you have good fuel flow to the carb. Last time I had a problem like you are I had some crud in the tank that plugged up the inlet to the fuel bowl. I blew back through it carefully with compressed air to clear it. I also had the gas cap off to prevent any pressure build up in the tank.
Texas Denny
08-07-2007 19:18:28
There is cleaning and there is cleaning. I recall having to take one through thorough cleaning three times before I got all the channels clean enough to work correctly. Your problem is either clogged channels and ports or a bad manifold or manifold gasket. There really aren't any other options.
37WC
08-07-2007 18:02:44
If you have to choke it to keep it running you may have an intake leak between the carb and the head. Check for cracks in the intake manifold and that the manifold bolts/nuts (to the head) are tightened properly. You may have to replace manifold gaskets.
Good luck
37WC
old
08-07-2007 14:20:46
Never seen one with a holley carb on it. All the WD45s I have seen had the good M-S carbs on them and they are almost bullet proof as long as you keep the fuel clean
wd45
08-07-2007 20:44:35
 Re: WD 45 carb in reply to old, 08-07-2007 14:20:46
OLD, Thanks for the info. But do I get one of them from? But, Most of all, why does this thing have A Holly on it? He bought it brand new, and it's never been changed that he Know's of!
old
08-07-2007 21:04:24
 Re: WD 45 carb in reply to wd45, 08-07-2007 20:44:35
Don't know why it has that on it and if or if not it was there when new. Who knows what a dealer may or may not have done to it at some time in the last 50 years. Now that carb could be a zenith and that would be could be correct. My book list one of 3 M-S carbs for it. TSX464, 581,or773 The TSX 773 is the one I see most often. Value bilt has them but there around $205 for one plus shipping
Mike Dunica
08-07-2007 14:13:42
Yell,just sell the WD45 to me
