Adjust clutch Allis C
MNallisC
08-07-2007 08:55:25
Can someone please tell me or show me where I can find directions on how to adjust the clutch on my Allis C? I have been having to hold in the clutch for a long time to get it to go in gear but lately that is not even working.
Thanks
Russ1
08-07-2007 15:42:00
 Re: Adjust clutch Allis C in reply to MNallisC, 08-07-2007 08:55:25
Remove the inspection plate under the clutch housing and you can see the pressure plate fingers and the throwout bearing. The fingers should be adjusted to have 1/4inch clearance from the throwout bearing. You will see the bolts on the pressure plate that are to be adjusted.
Texas Denny
08-07-2007 09:53:02
It has been a while since I've worked on one of these. I believe the connection to the throw out bearing yoke is threaded (inside) and the rod coming from the pedal is threaded (outside). To adjust the length of the rod, remove the rod from the clutch pedal and rotate the rod. In your case, you want the rod longer, so turn it counter clockwise two or three turns and try tractor again. Make adjustments in small increments.
My hunch is that the clutch disk has failed and is coming apart making disengagement difficult. If you make the clutch rod too long, the clutch will not re-engage if it ever does dis-engage.
If you get the clutch to work right, remember to adjust this rod so that there is some free play on the throw out bearing. If there isn't free play, this bearing will fail prematurely and the engine must be removed to replace it.
In the event that the clutch can't be made to work, you will need to remove the engine to fix it.
