excessive oil pressure
gregm
08-01-2007 13:37:38
Any suggestions as to why a recently overhauled engine ran fine for about five months of light to moderate regular use and then out of the blue start blowing the oil filter apart at the seams?
Ben Jones
08-02-2007 20:58:09
 Re: excessive oil pressure in reply to gregm, 08-01-2007 13:37:38
Hopefully the other folks are right about the problem being a relief spring stuck in closed position. I don't know that motor but usually the spring and associated valve or in the oil pump or located near the filter boss(like a Ford). Also, on some engines, if the cam bearings or not installed correctly the oil pressure can go thru the roof. That comes to mind because the engine was rebuilt recently. good luck.
gregm
08-02-2007 10:54:02
It is a d17 allis, and I have tried many different types of filters. Look at my same posting under the general discussion forum for a full discription of the problem.
old
08-01-2007 19:53:16
Well since I saw your other post I know its a D-17. I would say the oil pump relief valve is stuck. As to how to fix sorry I can't help on that
hd6gtom
08-01-2007 17:45:04
May we ask what tractor you have and what type and brand oil and filter brand you are using?
secret
08-01-2007 18:43:48
 Re: excessive oil pressure in reply to hd6gtom, 08-01-2007 17:45:04
It is a secret.
L.C.Gray
08-01-2007 16:08:06
Maybe the relief valve in the pump is stuck closed.
El Toro
08-01-2007 15:25:09
Have you measured the oil pressure to see what the max pressure is? You may have a defective filter. Hal
Will Herring
08-01-2007 14:59:59
Unsure... But first, have you changed the oil recently, and does it drip a noticable amount of oil when parked?
