WD 45 Compresion??
Ron
10-17-1999 22:05:36
I took a compresion test on my 45 and all 4 cyl. read about 95 psi. Is this good or do I need a over haul? The reason I ask is it seems to loose power going up hill, even if you aren't pulling any thing.
Dan
10-18-1999 18:22:15
 Re: WD 45 Compresion?? in reply to Ron, 10-17-1999 22:05:36
compresion should be ok.It sounds more like a problem with your governors.
AL
10-20-1999 05:59:46
 Re: Re: WD 45 Compresion?? in reply to Dan, 10-18-1999 18:22:15
A NEW OVERHAUL COMPRESSION SHOULD BE AT LEAST 140 AND UP TO 180 WITH HIGH COMPRESSION...TRY A RING SEALER LIKE THE PRODUCT RESTORE ...
