HOw do I remove the snap coupler Bell?
DavidKittle
07-30-2007 13:59:45
Hello;
I need to remove the snap coupler bell on my 63 D-17 serie III allis as I accidently " tapped" it and need to bend it into shape.
I have the lower pin (holding the hook)out okay, but the top one is STUBBORN. I am soaking with aerokroil, and try again tomorrow. But I am writing to find out suggestions that may help me out.
Thanks
Big Hunter
07-30-2007 17:35:39
 Re: HOw do I remove the snap coupler Bell? in reply to DavidKittle, 07-30-2007 13:59:45
you could go out and buy a "MAPP" torch kit. it is the yellow bottle, has the pull the trigger ignition. I forget how much it cost (I think it's like 20 or 30 bucks for 2 bottles and the torch end do-hickey) but it puts out way more heat then a propane torch and would probably do what you want.
DavidKittle
07-31-2007 16:17:11
 Re: HOw do I remove the snap coupler Bell? in reply to Big Hunter, 07-30-2007 17:35:39
Hi big hunter;
I got the mapp gas as you suggested and still no luck. I am trying to not damage the shaft with the hammer, also. Lotsa fun working wiht the torch trying ot get it out when it is 100 out there today as i was working.
So I soaked it again and maybe soon I will have some luck. Any help is appreciated so let me know what you think or can suggest on this.
william myers
07-30-2007 15:13:02
did u try putting some heat on it?
DavidKittle
07-30-2007 16:44:53
 Re: HOw do I remove the snap coupler Bell? in reply to william myers, 07-30-2007 15:13:02
william;
I don;t have a torch...I suppose I will have to patient and let the aerokroil do the work. At least , I know I had good luck with it in the past.
Have a good one
