WD45 valve adustment?
Hossman
07-29-2007 16:16:12
Fellas, I recently purchased an 56' wd45 and I just got done puttin the head back on after replacin a couple valves and a bent pushrod. I also lapped all valves while I had her "down". My question is on the valve adjustment, what I did was after gettin the head back on and valvetrain back in took the flywheel to the "DC" mark for the no.1 cyl(this mark is around 8 teeth left of the "F" or fire mark on the 45)anyhows I set both intake and exhaust valves on the no.1 cyl. at this time to .012,I then moved to the no.4 cyl(was told that 1&4 work together then 2&3)ok then I moved with hand crank till no.2 was tdc then adjusted it at .012 then no. three the same. Started the ol gal up she sounded real good let run for 20 minutes then shut her down and checked and readjusted as needed. Does this sound correct or is there a differant way to do this thats better? This was first valve job and was wonderin, the "book" leaves a little to the imagination for a first time rookie. I might ad I havent driven the ol gal yet as I wanted to let her cool down till before I install the valve cover gasket. Also I did retorque the head bolts after I warmed her up. I wanted to throw this out there and see what all you seasoned fellers did for your valve adjustments. Thanks alot, Hoss
El Toro
07-31-2007 04:36:50
 Re: WD45 valve adustment? in reply to Hossman, 07-29-2007 16:16:12
You can adjust them by having No1 piston at TDC on the compression stroke then adjust valves 1, 2,
3 & 5. Then rotate the engine until No 4 piston is at TDC on the compression stroke and the adjust
4, 6, 7 & 8. Hal
Texas Denny
07-29-2007 19:59:52
I've never paid any attention to the flywheel. Always just turned it over and watched the valves. You method seems sound but never figured it out.
Re-torquing head bolts when at operating temperature is good.
Hossman
07-30-2007 15:36:37
 Re: WD45 valve adustment? in reply to Texas Denny, 07-29-2007 19:59:52
Texas Denny, Thanks for the input I'm sure there OK (valves) they sound good and make no chatterin or noise. I adjusted them a (loose) .012, a buddy told me to keep em on the loose side rather than to have em to tight. Again, thanks for the input, Hoss
Texas Denny
07-30-2007 16:01:29
 Re: WD45 valve adustment? in reply to Hossman, 07-30-2007 15:36:37
Sounds good to me.
