HD-5 crawler tractor
veggie
07-29-2007 04:38:28
My cousin and I were given this crauler from my late uncle. He had it setting in a shed. I have it running but I can't get it to move. The last time that I drove it was 20 yrs. ago. I put it in gear and when I let out the hand clutch it will kill the engine. The steering levers feel normal but the brake peddles are hard as a rock. Is there a "parking brake" somewhere that has the brake pedals locked up? Thank you for any help you can give , Tom
hector gemme
07-29-2007 08:35:45
 Re: HD-5 crawler tractor in reply to veggie, 07-29-2007 04:38:28
I forget to tell you ,you should have a parking break bar under fett floor
hector gemme
07-29-2007 08:28:39
The break band must be stuck on drum ,you have to remove under the fuel tank a small cover and you should find a long nut 9/16 just loose her and if you can open on back housing each side a plate maybe 4 by 6 inchs and try to move the break band.
veggie
07-31-2007 02:51:10
 Re: HD-5 crawler tractor in reply to hector gemme, 07-29-2007 08:28:39
Hector ,thank you for the reply. Are you refering to the steering cluthes/ brakes ?
hectorgemme
07-31-2007 08:41:02
 Re: HD-5 crawler tractor in reply to veggie, 07-31-2007 02:51:10
HI Yes the stering cluch drum break band
veggie
08-06-2007 03:05:45
 Re: HD-5 crawler tractor in reply to hectorgemme, 07-31-2007 08:41:02
Hector, thank you for your advise. Saturday I took off the inspection plates, loosened the tension nuts and was able to get the brake bands free. We were then able to get the crawler out of the shed where it had set for over 15 years!! Thanks to your advise, we accomplished that !! The downside.... as I was operating it in the drive way, the upper brake band broke on the left side . Again, thanks for your help, Tom
hector gemme
08-06-2007 08:34:31
 Re: HD-5 crawler tractor in reply to veggie, 08-06-2007 03:05:45
HI Good luck to you and if sometime I can help you ,am still have some hd 5 parts
