Hook up of battery on d17
russell
10-17-1999 11:01:30
i am confused. i dont know how to hook up the battery on my d17. i negative supposed to go to the ground or the other way around. i am confused because it works either way ! i would think that the negative post would go to the ground but some crazy things were done.
thanks russ
Dan
10-18-1999 18:18:08
 Re: hook up of battery on d17 in reply to russell, 10-17-1999 11:01:30
first check voltage. if not 12v or more try charging it. neg (-) should always grounded to the tractor. pos(+) to the solinod.
Brian
10-19-1999 12:45:54
 Re: Re: hook up of battery on d17 in reply to Dan, 10-18-1999 18:18:08
All allis stuff with a generator is positive ground originally. It will work either way. All that is needed is put the pos post on the coil toward the switch if you're changing to neg ground and polarize the generator by momentarily shorting across the Battery and Generator posts on the regulator with a screwdriver or other fairly heavy piece of wire. Hope this helps, Brian.
