hydraulic pump
l gehring
07-27-2007 12:50:54
good afternoon gents
i have a hydraulic pump between the govenor housing and the magneto that has a constant drip. have any of you ever taken one apart? maybe just o -ring seals?
old
07-27-2007 13:56:02
 Re: hydraulic pump in reply to l gehring, 07-27-2007 12:50:54
Would help a lot if you said what its on. With what little you said we can only guess as to what your fix might be and even then theres only a small chance we would guess right
l gehring
07-27-2007 14:53:36
 Re: hydraulic pump in reply to old, 07-27-2007 13:56:02
a little more info.
this pump is on a sc case. it is the add on kind to make live power on lots of old tractors. it is about 6 inches long and is flange mounted between the govenor and the magneto. it has an inlet and an outlet coming out the top side. also has a add on reservior and control valve. it drips at both ends of the pump. i don't know what brand it is.the pump is a 3 piece casting bolted together with the in and out on the piece closest to the mag. i hope this gives you a better picture. thanks
old
07-27-2007 15:33:30
 Re: hydraulic pump in reply to l gehring, 07-27-2007 14:53:36
Sounds a lot like a vickers vane pump. It should have seals on both ends of the pump but not sure how hard it would be to find or install them
