WC AND D17 ENGINE??
T.R.Y.
07-27-2007 09:44:52
ia the d17 engine a direct fit for a wc. governor, linkages, clutch/trans shaft/pilot hole and the rest of the stuff??? I found a good engine to replace my shot wc one. also whats the best carb to run on the d17 thanks
t.r.y.
07-27-2007 13:02:35
 Re: WC AND D17 ENGINE?? in reply to T.R.Y., 07-27-2007 09:44:52
also is 750 for a running motor to much out of that d17 fellow said its a early model. its running but uses oil and needs over hauled. any differences good or bad with the early to late model d17's. thanks
old
07-27-2007 13:53:48
 Re: WC AND D17 ENGINE?? in reply to t.r.y., 07-27-2007 13:02:35
I've picked up complete tractors for a lot less then that. Shoot the tractor I used for parts for my WC Speed Patrol I payed $250 for the whole WD tractor and with just a little work it was running/driving just fine so yes $750 for just an engine that uses oil is high way to high. Now if that was a good running engine that didn't use oil maybe but it would still seem a little high to me
AC
07-27-2007 10:24:13
I have a good late combine carb off of a runner if you need one..mainfold too...AC 1 269 921 4686
