Allis Chalmers CA
Kenny M
07-27-2007 08:10:17
Need new brakes on my CA but theres no plate to remove to access them. Dads CA he farmed with years ago had a plate that could be removed, but this one does not. How do I access the breaks?
JW in NH
07-27-2007 09:10:00
 Re: Allis Chalmers CA in reply to Kenny M, 07-27-2007 08:10:17
My CA has the same setup. Remove the "DECK" to expose the axles. This entails removing the seat. Then remove the brake levers and pull the bands out through the opening. Remember whivh direction the band were facing ( so you can hook up th elevers again) When you replace the brake bands I found that a coat hanger pushed through first helps guide the band into place. Ypu will have something to pullthe "front of the band with while pushing on the other end. Good luck JW
