WD45 2-Row Cultivator
Toby(NC)
07-26-2007 19:51:14
I have a WD45 2-Row Cultivator, I think it is either a WD-3 or WD-4 and I'm missing the Strap/Plate Assembly that attaches the cultivators front frame to the tractors side rail on both the left and right sides.
Could someone out there either give me the dimensions of the plate or maybe know where I can locate two of them.
If I have the dimensions I can have a local machine make me some.
The photo below from a dealers parts number shows the part that I need. The part is circled.
Thanks,
Toby(NC)
third party image
JMS/MN
07-26-2007 21:59:31
 Re: WD45 2-Row Cultivator in reply to Toby(NC), 07-26-2007 19:51:14
Look at the side frames on the tractor- all double holes are drilled the same distance apart. Measure that, and have the welder weld the bolts to a quarter by one plate. Purpose of the plate is, you can stick it in from the backside of the tractor C-frame, and not have to put a wrench inside the frame to keep the bolts from turning. Or, just stick bolts through and put a wrench on them, and skip the plate. It's just a convenience issue, but very handy.
