1954 WD 45 Diesel 3 point conversion
Stan Patzer
07-26-2007 13:20:46
Looking to buy a 3 point conversion that attaches to the Yoke in the same manner as the drawbar. It also attaches to the 2 lift arms.
Wanted for attaching rotary mower to a 1954 WD 45 diesel.
BobHnwOh
07-27-2007 15:15:05
 Re: 1954 WD 45 Diesel 3 point conversion in reply to Stan Patzer, 07-26-2007 13:20:46
I built this setup and have used one just like it for 11 years with no problems,cost about $150,Bob. third party image
Will Herring
07-28-2007 08:35:11
 Re: 1954 WD 45 Diesel 3 point conversion in reply to BobHnwOh, 07-27-2007 15:15:05
Very nice. I am thinking about doing something similar to mine someday, if our old 6' rotary mower ever craps out on us and we have to get a new one.
BobHnwOh
07-27-2007 15:16:59
NO PIC????? ??
Bill(Wis)
07-26-2007 17:40:15
Get one that allows the traction boost to work. The best one is the one made by factory but is very rare. The top link on the after market version attaches to the rockshaft via a clevis. This will slip to the low side when mowing on side hills. An annoyance. Can be restrained with a clamp on either side.
Aaron SEIA
07-26-2007 15:57:34
Not sure that'll work. I've got one and there is a brace across the middle that would hit a PTO shaft. The ones that bolt to the drawbar will allow for PTO use, retains the traction booster feature, and lets you keep the drawbar in place. Have seen them on eBay and other sites for sale.
Aaron SEIA
Sid
07-26-2007 16:55:58
 Re: 1954 WD 45 Diesel 3 point conversion in reply to Aaron SEIA, 07-26-2007 15:57:34
"The ones that bolt to the drawbar will allow for PTO use, retains the traction booster feature." I have one like he is talking about around here somewhere. I have seen them used on three point mowers and no interference with PTO shaft. I have seen several mention on here that removing the drawbar will not allow the traction booster to work on these type of kits. I am going to challenge this statement. To use a snap coupler plow you have to remove the drawbar to mount the plow. This type of adapter hooks into the same place, bell housing, the tongue does on a snap coupler plow. Please explain why the traction booster will not work on a three point adapter with the tongue removed.
Aaron SEIA
07-27-2007 16:02:28
 Re: 1954 WD 45 Diesel 3 point conversion in reply to Sid, 07-26-2007 16:55:58
You are correct about the remove the drawbar adapters also letting the traction booster work. I've got one of those style on my cultivator. Guess my point was that style does not allow for PTO use 'that I have seen'. Mine has a support bracket across the 2 arms that would hit and bend a PTO shaft. The aftermarket ones appear to be the same as well. Thus, I stand by my original statement, the ones that bolt to the drawbar allow for all 3 functions, PTO work, traction booster, and use of the drawbar. The others do not.
Aaron SEIA
Sid
07-26-2007 16:55:27
JMS/MN
07-27-2007 12:26:58
 Re: 1954 WD 45 Diesel 3 point conversion in reply to Sid, 07-26-2007 16:55:27
The Snap-Coupler is the sensing device for automatic weight transfer, through the large spring above the SC. Notice that there is a pivot point above the SC, so as pull changes it slightly changes compression on the spring, and activates the linkage going up to the control valve. So, if nothing is hooked into the bell housing, there is nothing to activate weight transfer.
Coloken
07-26-2007 17:15:24
Just got done buying one. There seems to be 3-three types. Mounted on drawbar-traction booster works. Drawbar removed and mounted with snap coupler-traction booster works. Drawbar removed and 3 point mounted to rear axle diferencial- no traction booster. Might be otheres too...
