Allis Chalmers Roto baler
Chad in MN
07-25-2007 15:42:22
I would like to know how much a Allis Chalmers Roto baler is worth.. I found one and it is a orange top and it is in working condition and with extra parts and belts.. This unit is in really good shape, it has been stored inside.. please give me some ideas on how much it is worth.. Thanks, Chad
centralilbaler
07-27-2007 14:20:14
 Re: Allis Chalmers Roto baler in reply to Chad in MN, 07-25-2007 15:42:22
Dang i figured most of 'em were cut up along time ago!
Traditional Farmer
07-26-2007 12:23:38
$250 to $500 in the condition you describe.If you have never run one try to find someone that has to help you at first.Several little 'tricks' to make them work right but not a big deal to learn.I ran one for years we even bale a couple hundred a year now.Puts up the nicest hay of any baler.
John (MO)
07-26-2007 07:09:11
A couple hundred dollars should buy a good working one... or 2 that need some work.
hd6gtom
07-26-2007 06:56:54
They sell between 100.00 and 750.00. Remember you must rake hay different than you do for a square baler.
Rock_Picker(MO)
07-26-2007 06:00:49
If it works and is in good condition, it is worth MORE! Extra parts are a plus. Most Roto Balers sit outside, things rust, freeze up, or rot (tires & belts) and you spend a lot of time either fixing them, or looking for parts. I bought one several years ago here in SW MO, paid $225 for it, greased it, took it to the field, & used it. At the time, junkers were available for about $100. So to me it was worth the extra $$..... ....RP
old
07-25-2007 19:05:15
My self I have passed up probably 20 of them in the last few years at auctions. They all sold for less then $100 and most around $25-50. My self I would never own another one but I have had some bad times with one and I just plan hate them but thats a very long story
hillbillyOH
07-26-2007 06:08:58
 Re: Allis Chalmers Roto baler in reply to old, 07-25-2007 19:05:15
What exactly is a roto-baler? A hay baler or a combine of sorts?
I've never seen one.
old
07-26-2007 09:15:28
 Re: Allis Chalmers Roto baler in reply to hillbillyOH, 07-26-2007 06:08:58
They where made back in the 60s and 70s. They would make a round bale the same size as a square bale and where made to be pulled by a small tractor like the Allis B
massey333
07-26-2007 16:20:53
 Re: Allis Chalmers Roto baler in reply to old, 07-26-2007 09:15:28
Old,the first ones came out in about 1949 and if you tried to pull one with a Allis B,then I can see your problems because they could give a WD all it wanted at times.A CAwith live power wouldn't run one unless it was very-very light hay.
old
07-26-2007 16:33:08
 Re: Allis Chalmers Roto baler in reply to massey333, 07-26-2007 16:20:53
Well as per the papers that came with them they said a B could handle one just fine. Ya I did pull one with a B but switch to a Ford 841 and I still learned fast to hate them. I wasn't 100% sure when the first ones came out but knew they where made up till the early 70s
Garry from SD
07-27-2007 07:36:12
 Re: Allis Chalmers Roto baler in reply to old, 07-26-2007 16:33:08
Hey Old, The Roto worked best with the WD/WD-45 becuase of the hand clutch. The late model WCs didn't even work that well with the baler. If you used any other tractor brand, then you can expect headaches because you needed the live power.
old
07-27-2007 09:06:00
 Re: Allis Chalmers Roto baler in reply to Garry from SD, 07-27-2007 07:36:12
Live PTO on any baler works better then the non live PTOs
Traditional Farmer
07-26-2007 18:20:59
I have run one with a B its a load but a B will do it.A fellow near me bales about 100 bales a year with a tiny Yanmar hooked to the Roto baler.
Looks silly but he gets the job done
hillbillyOH
07-26-2007 18:17:14
Thanks for the info, gentlemen.
Garry from SD
07-25-2007 16:04:31
I was at a farm auction where they had an AC Roto-Baler with an orange top and it went for $210. It wasn't in near as good as shape as the one you described.
