Allis-Chalmers Combine
DCW
07-24-2007 18:07:13
My uncle has an Allis- Chalmers combine,a ''Gleaner'',Corn and Soybean special.I know very little about AC machinery,this combine is whipped,but the engine turns over,and it looks like an engine found in some AC tractors (WD45?).The engine and the tires are all thats any good.Where would I find some identifying tag on it as to year and model,and possibly information identifying the engine in it?I believe it to be mid 50's vintage,there is no cab on it,you sit out in the open.
Thanks in advance.
Skyhighballoon(MO)
07-26-2007 07:08:10
 Re: Allis-Chalmers Combine in reply to DCW, 07-24-2007 18:07:13
If it has the 4 cylinder 226 cu gas engine like a D17, it's either a Gleaner E or EIII. I guess it is possible that someone bought newer Gleaner "Corn/Soybean Special" decals and put them on an older unit. Mike
JMS/MN
07-24-2007 21:44:32
Look on the left side of the machine, just forward of the rear axle, if it is a self-propelled combine. About the height of your shoulders, near the battery. Should have an ID tag with a serial number stamped into it.If it is a Corn/Soybean special, it has a bigger engine than a WD45 would have, much newer.
