7060 noise in rear end
T Lawson
07-23-2007 09:45:05
I am looking at a 7060 red belly. The tractor is in good condition. It has the 20 speed power shift and does not slip or pop out of gear. I went through every gear and it did just fine. But, I noticed a clanging sound in the rear end at idle speed when it is in neutral. When you turn the RPM's up slightly the noise goes away. Any idea what this is and what it would cost to repair. Thanks
wilson2
07-24-2007 15:21:48
 Re: 7060 noise in rear end in reply to T Lawson, 07-23-2007 09:45:05
I have a 7010 and use to have a 7060. Both of them had the idle noise. This is from straight gears in the rear end for the PTO slapping if you will. Some of the old Case models have the same sound also.
Jack a
07-24-2007 03:41:47
They all do that. Nothing wrong. Some have set the idle at around 850 rpm to get away from the rattle.
Jack a
07-24-2007 03:29:10
BobHnwOh
07-23-2007 15:16:13
Is the PTO runnin??Bob.
T Lawson
07-24-2007 10:18:17
 Re: 7060 noise in rear end in reply to BobHnwOh, 07-23-2007 15:16:13
No the PTO is not running.
