noise in 7060 rear end
T Lawson
07-23-2007 09:42:56
I am looking at a 7060 red belly. The tractor is in good condition. It has the 20 speed power shift and does not slip or pop out of gear. I went through every gear and it did just fine. But, I noticed a clanging sound in the rear end at idle speed when it is in neutral. When you turn the RPM's up slightly the noise goes away. Any idea what this is and what it would cost to repair. Thanks
CAL (KS)
07-23-2007 10:41:41
 Re: noise in 7060 rear end in reply to T Lawson, 07-23-2007 09:42:56
the noise is most likely due to vibration, from torque limiter and or pto shaft traveling to the rear of the tractor through the pto shaft. My father has a maroon belly 7080 that does the same thing. very noisy at idle. been that way as long as i can remember. dont think its anything to worry about. just speed the tractor up a little bit when idling.
