WD-45 Compression Test
Rick Fanning
07-23-2007 08:52:53
Can anyone tell me what the compression reading should be for the four cylinder 226 CI engine on my WD45? I was getting readings of 120, 105, 107 and 117 but I'm not positive the engine was completely warmed up. I have been getting water in the oil although the engine seems to start and run OK.
Thanks,
Rick
Texas Denny
07-23-2007 19:49:09
 Re: WD-45 Compression Test in reply to Rick Fanning, 07-23-2007 08:52:53
Water in the oil can also be caused by bad o-rings at the bottom of the sleeves. If the water is coming from the head area, there should be some evidence when you remove the head - gasket problem or water in the cylinder. If it is bad o-rings, your head and cylinders will look fine. It is hard to see a cracked block at the crank area but this can also happen. As old says, pull the head off. This problem never heals itself and no matter what is wrong, the head must be removed.
old
07-23-2007 10:58:09
The center 2 aren't all that good but the other 2 are in the ball park for an old engine. Since you say you have water in the oil I'll almost bet you have either a bad head gasket and its leaking between 2 and 3 and thats where the water is comeing from or it has a cracked head
John (MO)
07-23-2007 10:22:30
You might want to read the earlier posts about differential compression tests. In my opinion a old engine running compression check is pretty much worthless. As you can see, you know your cylinders aren't the same, but you don't have much idea why.
