best pulling carb for wc?
Peter Hendricks
07-22-2007 11:24:41
please help me out I want the most power out of my stock wc for pulling and think I should get a bigger carb, but what one
Pete
garyh TEAM ORANGE PEEL
07-23-2007 09:25:16
 Re: best pulling carb for wc? in reply to Peter Hendrickson, 07-22-2007 11:24:41
PETE, next time your here for a pull leave it with me and I'll paint it. It wont pull any better but it will be pretty! You got plenty of power to parade! In fact I'm sure your WC went further than my WC saturday. See you this sat for the parade and pull if Ican find a bigger carb ..... Jes' kidden. gh
Dick L
07-23-2007 08:00:59
If you have not done anything to the engine to pull more fuel thru then the carb that is on it will do all you need. If you have it stroked and or larger pistons then a larger carb might be in order. Horse power is made in the engine not the carburetor. Increasing the venturi size will take away lugging power and increasing the fuel will make it run rich which will reduce horse power.
mlpankey
07-22-2007 22:13:21
a marvel shebler usx 20
mlpankey
07-22-2007 22:23:19
 Re: best pulling carb for wc? in reply to mlpankey, 07-22-2007 22:13:21
A MARVEL OR HOLLEY OFF A FORD LIKE A 901 WORKS WELL THE USX 20 WORKS WELL FOR 100HP+ENGINES
CENTAUR
07-22-2007 13:48:41
A smaller carburetor often will out perform the original one.The following is a true story.In 1956 OLDSMOBILE used one two barrel,large throttle body and venturi from the factory on the V/8s.Every time you opened the throttle it would fall flat on its face&die because the engine did not have vacum to continue to run.BENDIX/STROMBERG made a replacement which had much smaller venturi and throttle valves.This gave the car instant acceleration and up to 100 MPH and much better MPG.So their are many factors to consider in your case CENTAUR
old
07-22-2007 11:56:05
Maybe one from a WD45 if it would bolt on it would be a little bigger but one problem is you can only put in so much gas before it starts to run to rich and if your engine is stock then you will not gain much if any thing with a bigger carb
