WD45 head studs
MIke from cny
07-21-2007 23:20:50
Was wondering if anyone could tell me where the 1/2" head studs go in the block that hold the head on, there are 2 and the rest are head bolts. I got the motor in a basket and its almost done. Thanks for your help.
mlpankey
07-22-2007 01:41:22
 Re: WD45 head studs in reply to MIke from cny, 07-21-2007 23:20:50
the studs will go in the inside holes that holds the water neck on . be sure that the outside bolts in the water neck are the same length. they should be longer than the rest. if you put a short one there it might pull the threads out of the block cause you cant get a half inch thread engagement .
