surging G
riverbend
07-21-2007 18:46:18
I'm borrowing the neighbor's G and it would not take any throttle, so I put in a set of plugs, points, condensor, new wires, cap, rotor, and reset the timing. It was much better. When I got into some heavy going it would surge.
When I took the carb apart to clean it, I saw that there was what looked like tracking in the dust on the outside of the distributor cap. Is that a red herring, or should I have another look at the ignition ?
Other ideas ?
Thanks
Greg
riverbend
07-22-2007 06:48:02
 Re: surging G in reply to riverbend, 07-21-2007 18:46:18
A little more information -
When the engine is surging, the governor is working back and forth. If I reach back and hold it steady, the engine speed smooths out. When I took the plugs out, the insulator tips were very light.
Greg
Dick L
07-22-2007 06:54:00
 Re: surging G in reply to riverbend, 07-22-2007 06:48:02
You will find an adjustment screw on the side of the timing cover. You can see it from the left side og the engine. Easy to get at. Turn it in slightly.
Joe M(GA)
07-22-2007 13:24:58
 Re: surging G in reply to Dick L, 07-22-2007 06:54:00
third party image
third party image
riverbend
07-22-2007 15:49:27
 Re: surging G in reply to Joe M(GA), 07-22-2007 13:24:58
Thanks guys. I'm going out to cultivate for a couple hours. I'll turn the bumper screw in a touch and keep the screwdriver and wrench with me.
Greg
riverbend
07-22-2007 18:59:30
 Re: surging G - that worked! in reply to riverbend, 07-22-2007 15:49:27
You are scholars and gentlemen. The little runt would bull its way through hard soil infested with quack grass and never miss a beat.
I posted a picture of the tractor over in the 'tractor photo' section if you care to see what you have been helping out with.
Thanks again
Greg
