WD PTO shaft repair?
Rock_Picker(MO)
07-18-2007 19:15:35
Some "dummy" (me - don't ask) bent the pto shaft on my WD between the carrier bearing and the splines. A couple of questions:
1) How do I remove the carrier bearing from the shaft? I can't find any keepers or pins. Is it just pressed on?
2) Has anyone straightened of these shafts? Was the repair successful?
Any suggestions or "do's & don'ts" would be appreciated..... ..RP
JMS/MN
07-19-2007 12:41:26
 Re: WD PTO shaft repair? in reply to Rock_Picker(MO), 07-18-2007 19:15:35
Depending on where the bend it- it may not be necessary to remove the bearing to straighten the shaft. Just set the 'V' blocks equidistant from the center of the bend.
Texas Denny
07-18-2007 20:01:43
The bearing has a seal on front and back. Behind the oil seals are snap rings. You may have to destroy the oil seals to get them out.
A friend of mine bent his shaft on his 45. He brought it into the machine shop at work and they straightened it on a press. I just straightened one on a Massey Ferguson - had nearly 3/4" runout. It take about 12 ton or more to straighten these shafts. You may never get it perfect again but you should be able to get it serviceable. Takes a bit of skill and patience but it can be done.
