Front crank seal question
Jim Weatherby
07-18-2007 16:00:02
Has anyone here ever changed the front crankshaft seal on a 2900 series engine? Mine's leaking pretty bad and I'm getting ready to replace it. Just wondering if there's anything I need to be aware of before I get started. I have an IT shop manual but it seems pretty vague. Thanks in advance, Jim
El Toro
07-18-2007 16:13:27
 Re: Front crank seal question in reply to Jim Weatherby, 07-18-2007 16:00:02
The old seal probably has worn a groove into the hub on the damper pulley. There's probably a speedi-sleeve kit available to cover the worn area. I will let someone else give you the instructions for gaining access to the timing gear cover. I think the grille and radiator will
need to come off. Hal
