WC Mag help
Motec
10-14-1999 06:34:33
I am working on a 1935 WC tractor with a mag. It is the OLD Fairbank Morris with the plug wires comming out the top. I sent it out and had it rebuilt. It works, but it is very hard to crank start. I went into it and tightened the impaulse but that didn't help much. I have put on a newer mag, and the tractor will start with one pull of the crank. Please send advice before my arm falls off from trying to start this fine tractor.
Brian W
10-15-1999 04:19:40
 Re: WC Mag help in reply to Motec, 10-14-1999 06:34:33
Try Brian's mags. He seems to know alot about them. I've seen him post from time to time. Sorry I don't know how to reach him. Good luck, Brian W.
Rick Wisehart
10-18-1999 17:11:51
 Re: Re: WC Mag help in reply to Brian W, 10-15-1999 04:19:40
You said the Mag was rebuilt are you sure,it sounds like the new mag may have a better spark then the mag you said was rebuilt or the older mag is not in time.Personaly I would start by taking the older mag apart to see if a new coil was installed and pay close attention to see that the mag is timed, also if it was rebuilt like you said it should have a new coil in it plus points and condenser.How much did you pay and who rebuilt your mag e-mail me please with this info.May be that you got a bad rebuild.
