magneto question
l gehring
07-16-2007 20:27:57
on a fairbanks morse mag, having removed the 2 caps and looking at the points, should you see a spark when you turn it? even though the connection from the coil to the rotor has been removed.presuming everything is working correctly. thanks, l gehring
stu (ON)
07-17-2007 04:06:51
 Re: magneto question in reply to l gehring, 07-16-2007 20:27:57
You may find some help here.
Bob
07-16-2007 20:34:32
Rather than letting the coil secondary spark into an open circuit, ground the shank of a screwdriver to the mag's case, and manuever the screwdriver's tip about 1/8" from the high-tension terminal on the coil, and see if you have spark.
Simply letting the coil "fire" into an open circuit is NOT good for the coil.
l gehring
07-17-2007 18:43:46
 Re: magneto question in reply to Bob, 07-16-2007 20:34:32
gentlemen, thanks for the info. tried the srcewdriver trick. now i know my coil is good. now i'll buy the fiber gear and be in business
