oil pressure
joeh14
07-16-2007 08:31:19
For about the last year I've been using my tractor WD45 and the oil pressure gauge didn't work or register anything. I bought a new gauge and it won't register anything either. What do I need to check for? The tractor has been running perfectly fine.
02XLT4X4
07-16-2007 12:08:32
 Re: oil pressure in reply to joeh14, 07-16-2007 08:31:19
As I recall most older Allis engines don't require the oil to go thru the filter, there is a junction where it can either go thru the filter or back thru the engine. I don't remember for sure if the WD-45 is like that or not. The idea is if your filter is plugged or not correct it won't starve the engine, unfiltered oil is better than no oil.
El Toro
07-16-2007 11:50:03
Is there any oil from the tubing when you remove the gauge? Your oil gallery may be blocked from sludge. I think it would be knocking if the bearings were not getting oil. Hal
old
07-16-2007 08:57:52
If you have the wrong oil filter on it you will have little or no oil pressure. You need to run a fram 159 I think or a wix 57011
Texas Denny
07-16-2007 08:56:22
You may be using the wrong filter. The filter must be stuffed cotton with a small stick (1/4") stuck in the center which you remove when installing the filter. I use Fram 159 which is available at Tractor Supply. Many filters that are listed as a replacement WILL NOT WORK. You have been running your tractor without oil pressure which probably has hurt it substantially.
If your filter is right, and you still have no oil pressure, either your oil pump is bad or your engine bearings are worn out. If the bearings are worn to this point, I would expect considerable engine noise.
A third possibility is that the gauge you bought is bad. I bought a gauge for my Allis D-14. When I installed it, I had very low oil pressure (there was some). It turned out that the gauge had a 0-100 psi range. I think the 14 requires 0-40 range. These things do happen.
arthur ward
07-16-2007 08:42:22
well i would check for oil
