engine missfire or spudder
TIM WILBUR
07-16-2007 06:39:57
engine has missfire or spudder in road gear after load is caught up with. i release clutch and tractor runs fine untill i reach top speed an load is reduced at which time engine spudders. after which it run fine.i have tried the full load adjustment with no luck. any ideas. thanks tim
Jerry Coulter
07-16-2007 06:56:50
 Re: engine missfire or spudder in reply to TIM WILBUR, 07-16-2007 06:39:57
Take off the dist cap and rotor, wiggle the dist shaft to see if the bearing is worn. Can you see the points moving without turning the rotor? Also, might be a vacuum leak at manifold gasket, cracked manifold, bad gasket in carb, etc.
TIM WILBUR
07-16-2007 07:56:59
 Re: engine missfire or spudder in reply to Jerry Coulter, 07-16-2007 06:56:50
THANKS JERRY, MANIFOLD LEAK SOUNDS RIGHT BECAUSE IT RUNS VERY LEAN, SPARK PLUGS ARE WHITE. TIM
