Snap Coupler hitch
Leroy
07-16-2007 05:05:49
I normaly hang on the other boards, The lead story today on the WD 45 says that the snap coupler came out one year after the WD 45 series was started. My question is if it didn't come till then what was the hitch on all the WD's and CA's before that called and I can't recall ever seeing a WD-WD45 or CA with out the hitch. I am 63 and have been around the tractors all my life. Or is that a misteak in the artical?
John (MO)
07-16-2007 06:17:45
 Re: Snap Coupler hitch in reply to Leroy, 07-16-2007 05:05:49
WD45 started with serial number 146607, snap coupler became standard in 1954 with serial number 151381. The hitch prior to that on the WDs, WD45s and CAs was a pin hitch. Many many of those tractors were converted to snap coupler in the first few years after it was available.
John (MO)
07-16-2007 09:54:47
 Re: Snap Coupler hitch in reply to John (MO), 07-16-2007 06:17:45
I do believe the snap coupler bell was optional for a while before it became standard equipment, but right now I don"t find anything that says that. Back in the 50"s I remember a couple pin hitch ends hanging in the shed that had been removed from things and replaced with the eye for the snap coupler, also a couple more of those hung around, I guess waiting to replace a pin hitch if equipment was bought at auction with that old hitch. It wasn"t really a common thing that we had extra parts on hand either, so it makes me think the dealers sold those parts real reasonable.
Leroy
07-17-2007 05:19:38
 Re: Snap Coupler hitch in reply to John (MO), 07-16-2007 09:54:47
How does the pin hitch where the bell is on the snap coupler hitch work? Is there some type of bell there for that part of the drawbar to slide in but with a different fastening system? Is it something that the uninformed could mistake for a snap coupler bell? I thought the earlier and later hitches both were the same at the front part but just a different coupler at the back ends of the lift arms. Was around the neighbors tractors but never that close to them.
John (MO)
07-17-2007 07:05:31
 Re: Snap Coupler hitch in reply to Leroy, 07-17-2007 05:19:38
third party image
This is the best picture I could find of a pin hitch implement. You lined up the hole in the implement tongue between the 2 holes where you removed the tractor drawbar. Not an easy job for 1 person. 2 people doing it was better, but one needed to be under the tractor while it was moved. OSHA would have a fit today.
The lift arm latches were basically the same with either a pin hitch or snap coupler. The design changed a little over time but they are really interchangable.
Leroy
07-18-2007 18:40:26
 Re: Snap Coupler hitch in reply to John (MO), 07-17-2007 07:05:31
Thanks, I think I understand now.
Texas Denny
07-16-2007 06:15:03
Well, I'm confused, too. I thought it came out WITH the WD-45. Many of the WD's were retrofitted with the new design - Allis must have been reasonable in the cost of those parts because a lot were changed. You have to applaud their designers for making the parts able to be retrofitted.
"Snap Coupler" is a trade-mark and as such only refers to the lower snap with the bell and the latches on the lift arms.
The WD hitch was different requiring pins to be inserted in the bottom and both lift arms.
