D-14 Uneven Running
Texas Denny
07-13-2007 20:38:43
The last time I was shredding, after three hours the 14 seemed to not run as smooth as normal - like a fouled plug but not as regular. I pulled all the plugs and they looked like new. I used it on the baler today and the same thing started after about an hour. So, I went to the carb and turned the power jet out about 1/4 turn. The engine evened out immediately. I guess I should have thought of this sooner but it is odd to have this adjustment needing change after it had run perfectly for several years. The needle was not easy to rotate and the spring was tight. Live and learn.
