A couple of Allis C questions
Jim in NC
07-12-2007 20:07:59
What is the factory rear tire size? The one, a '49 model, I bought a few months ago has almost new 8.3x24s on it. They seem small to me. Also, what is the approximate setting for the idle mixture screw on a Marvel-Schebler carb. Mine is almost all the way in, but idles and runs well. I have soaked in carb cleaner twice for about 24 hours at a time with no change. Thanks for the help.
chalmersbob
07-13-2007 18:15:35
 Re: A couple of Allis C questions in reply to Jim in NC, 07-12-2007 20:07:59
early c had 9-24 tires later ones used 10-24 on a 9" rim. Bob
Dick L
07-13-2007 07:16:50
If it idles correctly dont worry about it. I have had them not turn in far enough to idle properly. I would take even money that it had water in it some time and the needle or seat has pits in one or the other. Might even have the tip of the needle gone. Sounds like you already know but you start adjusting at 1 1/2 turns out. You then work back and forth with the stop screw on the back of the carburetor turning the idle screw in until you have the idle set. I have never had the idle setting get out of adjustment once it was set.
Sid
07-12-2007 23:07:20
According to manual rear tire size is 9-24. The only thing I find is idle speed of 400rpm. Adjusted when engine hot. As I remember that was not out very far. Book mentions both carburetors were used.
old
07-12-2007 21:59:57
I think but can not be sure that when new they had 12X24 on them, maybe 11X24s. As far as the carb I have never seen a MS carb on them. Should be a zenith model 61AJ7 or 161J7
Jim in NC
07-13-2007 03:26:40
 Re: A couple of Allis C questions in reply to old, 07-12-2007 21:59:57
Thanks for the quick responses. My books, an IT and an original, say a Zenith or a MS was used. Also, the smaller rear tires allow the rear mower mounts to dig into the ground when on an uneven area. I hate to get the torch on it.
