D15 series 1 noise in rear
Thomas L Clark
07-10-2007 19:49:40
I have a D15 series 1 that I use when I rake and bale. I try not to take it on the highway whenever possible but that is not always possible for my situation. It developed a popping noise in the right rear sounds like it is comming from the middle of the wheel. I checked different things and found it doesn't make the noise when the clutch is in or when the high low lever is in neutral. I don't think a gear is broken but maybe something with the brakes??? I had to hold it back the last hilly field I baled. Thanks for any help anyone could give...Tom
Sid
07-11-2007 06:16:25
 Re: D15 series 1 noise in rear in reply to Thomas L Clark, 07-10-2007 19:49:40
Did you check lug bolts?
william myers
07-11-2007 02:29:05
Check the rim locks r tight on the power slide.. It will make a popping sound if not tight...
old
07-10-2007 20:41:12
Most of the time a popping means you have a bearing going bad. Run it as little as you can till you can have a look see because if it is a bearing it can/will take out more parts the more you use it
