oil seal for pto on wd
Randy Reber
07-10-2007 13:44:55
Does any one have a napa part# for a oil seal for my wd pto shaft?
Thanks
Randy
stu (ON)
07-10-2007 20:29:50
 Re: oil seal for pto on wd in reply to Randy Reber, 07-10-2007 13:44:55
The original was AC10061S
AGCO now supplies National 470061 but it is a new design and not as thick.
Others have used National 6241S or 470950.
Chicago Rawhide used to supply thicker seals like OE, but they were acquired by SKF and their products were folded in. See SKF web site for more cross-references.
Note that many of the current replacement seals are .003" larger in outside diameter than the originals and so are a tighter fit in the bore of the bearing cage.
Randy Reber
07-11-2007 13:02:14
 Re: oil seal for pto on wd in reply to stu (ON), 07-10-2007 20:29:50
Thanks for the info, I got the seal at napa & changed the seal, only lost about a quart of oil during the switch. No more drips
patsublett
07-10-2007 17:15:05
The old seal should have a number on it, if not take it to a bearing place, they can measure it and match it.
