Plow Shares
WD_Fan07
07-08-2007 11:06:09
Anyone good with part no.'s? I was wondering what shares will fit a #364 slat bottom on a #73 plow. The old shares are #326080 and as I measure them they are for a 12" bottom, while the #364 is a 14" bottom as far as I know. I found some shares #326082 which are 14". Would these fit?
ArnieOH
07-08-2007 21:17:32
 Re: Plow Shares in reply to WD_Fan07, 07-08-2007 11:06:09
According to the Allis Chalmers dealers parts catalog, the 14" shares that you have will only fit #361, 362, & 363 Bottoms. The 364 would take Part #326080, however that may be superseded by the newer shares with 4 bolt holes for #374 slat bottom. That part # is 344188. Check with your local AGCO dealer, they should still be able to get shares for the 60, 70, & 80 Series plows, but hang on to your checkbook!!!
Hope this helps!
WD_Fan07
07-08-2007 21:20:54
 Re: Plow Shares in reply to ArnieOH, 07-08-2007 21:17:32
So the #364 slat bottoms had different hole patterns than the solid board models??
George NYS
07-08-2007 11:11:12
If the boltholes line up, you can always cut the ends off with a torch.
