anchor pin
joeh14
07-07-2007 11:24:15
I have a 1954 WD45 in which the brake rod broke. I need to take the brake shoe assembly out, but I can"t get the anchor pin out from under the axle. I"ve beat oiled and hit it till I was blue in the face. Any tips or suggestions would be welcomed. I still use this tractor ( ol rusty nuts ) to do all my plowing and planting.
fence row
07-23-2007 20:59:05
 Re: anchor pin in reply to joeh14, 07-07-2007 11:24:15
the anchor pins can be a problem but they make a puller for that reason. look up the web site agrimsontool.com tight or rusted pins it works great. about 170.00
joeh14
07-10-2007 09:19:17
thanks, thats a great idea, one question... what do I put the candle wax on?
JMD/MN
07-08-2007 06:23:59
Find a piece of flat iron, about quarter by 1 1/2 by 10 inches. Drill a 3/4 hole near one end. Weld it onto the pin. Gives you a handle to wiggle with, pound on, and the heat of welding helps loosen. Apply candle wax as it cools. Grind off the weld and reuse the pin. Put Never-Sieze on it.
JMD/MN
07-10-2007 09:25:30
 Re: anchor pin in reply to JMD/MN, 07-08-2007 06:23:59
thanks thats a great idea! one question... what do I put the candle wax on?
Texas Denny
07-07-2007 12:49:45
I think the easiest way is to loosen the large bolts that hold on the rear axle. On a 45, you'll probably need to loosen the bolts for the side frame as well. Remove the rear wheel and fender and support your tractor well. When you can jiggle the axle, it helps to loosen the pin. I tried three times on my D-17 before giving up. Then when I had to repair the cylinder inside the rear axle, I hit on the idea of jiggling the axle. They came out easily that way.
