Allis Chalmers B
Duke Hanson
07-06-2007 15:12:47
Does anybody know if they put the ajustable front end on the B? The ser # says its a B but it has a front end like a CA.
steve(ill)
07-07-2007 20:12:03
 Re: Allis Chalmers B in reply to Duke Hanson, 07-06-2007 15:12:47
Bob- the serial number of the tractor is by the shift lever on the transmission--- that will give you the year built.
steve(ill)
07-07-2007 07:07:11
if you have an adjustable front end, you will have the rear wheel hub that bolts on with 5 studs like the C, and not the 2 inch center nut like the normal B. that was an option for many years.
Polack
07-07-2007 04:12:28
I have a 1947 that has one.
Polack
Ted in NE OH
07-06-2007 15:49:14
Yes they did. The early style had an arch with adjustable axel shafts. ( Didn't work too good) and a later style that is like the CA.
Bobby rakestraw
07-06-2007 17:46:11
 Re: Allis Chalmers B in reply to Ted in NE OH, 07-06-2007 15:49:14
I just purchased one of the later ones and was wondering if you knew when they made the series of wide front "B" with a straight axle.
Allis nut
07-06-2007 21:50:49
 Re: Allis Chalmers B in reply to Bobby rakestraw, 07-06-2007 17:46:11
If I am reading it correctly they produced the adjustable front end starting in 1947.
Bobby Rakestraw
07-07-2007 12:37:48
 Re: Allis Chalmers B in reply to Allis nut, 07-06-2007 21:50:49
Then I can assume my tractor was made between 1947 and 1957. Do you know of any other features that I may use to narrow the years?
