Starter and swtich position
RC farms
07-05-2007 11:48:46
When I installed a rebuilt starter on my C the switch sits at a 45 degree (outboard) position which is not aligned with the starter rod pivot connector. Is there an adjustment that I can make to the starter to properly align the switch connection to the rod? I don't want to mess up the starter in any way.
Thanks,
Ron
Jerry Coulter
07-06-2007 04:14:27
 Re: Starter and swtich position in reply to RC farms, 07-05-2007 11:48:46
Sounds like you may have a WD starter. If so, you need to change the drive end housing and the bendix drive from the old starter. There are 4 different drive end housings: B-C, CA, WC, and WD. If it is a WD starter, your lucky break is you have a 4 shoe field which will pep up the torque. The other starters have a 2 shoe field. The B-C and CA starters have a larger diameter bendix drive with more teeth than the WC & WD starters.
RC farms
07-06-2007 05:30:03
 Re: Starter and swtich position in reply to Jerry Coulter, 07-06-2007 04:14:27
Unfortunately I mailed back the old starter to the supplier. So the gears will not mate up to the C fly wheel if this is a WD starter?
Jerry Coulter
07-06-2007 14:45:30
 Re: Starter and swtich position in reply to RC farms, 07-06-2007 05:30:03
I've been out to look at my tractors, now I'll try to give you some facts to work with. On my WC, the starter switch and set screw hole are on the same plane. From behind the tractor, they are on the left with the housing opening to the flywheel 90 deg. directly down. The WD has switch and set screw 180 deg. apart, screw on left and switch on right while opening is directly down. Both have 10 tooth bendix drive.
The B-C starter has more than 10 teeth. I don't believe a 10 tooth gear would mesh properly, but I never tried it. Anyway, with the switch on the bottom for a push rod, screw on the right, the flywheel opening has to be angled to the left and a little downward because the starter rides a little above the center point of the flywheel. The DR# 1107043 should be stamped on the starter. If it is a CA starter, the switch is on top for a pull rod.
Once you determine what you possess, you can take issue with your vendor on an informed basis.
old
07-05-2007 21:17:14
Well since no one else has answer you I will but this is just a guess. Take the bolts out and see if its will work if you turn it 180 out. But as I said this is just a guess since I have never had this problem
RC farms
07-06-2007 05:31:54
 Re: Starter and swtich position in reply to old, 07-05-2007 21:17:14
Thanks that might be what I have to do, but I've sent an e-mail to the supplier to double check.
