wd-45
mich
07-04-2007 18:29:33
I have a wd 45 1953,it has an issue shifting in gear with the clutch pushed in,unless you move the hyd. lever all the up to put the tractor in gear, once in gear, lever up tractor drags, does not roll free when you let out,however if you put hyd.lever down tractor operates correctly until you shift tractor to neutral and let clutch out,I have a IT manual I suspect hyd. pump and pump cam still turning all the time, manual does not much info. about adjustment, would anyone know is this a hyd. pump problem or engine clutch problem? THANK YOU
old
07-04-2007 20:38:13
 Re: wd-45 in reply to mich, 07-04-2007 18:29:33
I agree with Denny
Texas Denny
07-04-2007 19:34:13
Once you push in the clutch, you must wait a few seconds (up to 15) for the gears to quit rotating before you can shift into gear without gear clatter. If you push the hydraulic lever all the way up, the hydraulic pump is working against the relieve valve which absorbs all gear rotation energy very quickly. You should not have this lever in this position unless you are changing the lift position. Once you get fully up, the lever should be pulled down to the hold position. Sounds like your tractor is working properly.
mich
07-05-2007 08:25:35
 Re: wd-45 in reply to Texas Denny, 07-04-2007 19:34:13
Thanks to everbody that replied,I seemed a bit odd that the trator functioned that way,I will try all suggestions and maybe have a look at things again Thanks
big jt
07-04-2007 18:49:34
I would guess your shifting problems are clutch related.
jt
wolfman
07-04-2007 18:39:29
On 45's you always pull the hydraulic lever off a notch so pump doesn't continue to pump-it relieves, relaxes. Lift the implement and pull the lever back just a tad til you here it quit pumping, then it'll shift easily and tractor will move freely.
