WD45 comp. follow-up
Hossman
07-04-2007 08:30:29
Fellas, I got the valve cover off an as alot of ya said the exhaust valve for no.2 cyl. was stuck open. Pryed the dang thing "shut" and upon further inspection found the pushrod bent pretty bad.Took a brass rod and tapped the valve back down,well in the coarse of the tap down pry up procedure(about the third time)I managed to break the valve stem(it popped, and keeper,spring went flyin.) Managed to find the spring and the keeper.I felt this was goin to have to be a all or nothin deal on account of a new pushrod was just gona get bent also if I didnt get the valve workin easier anyhows. Well looks like I'm gonna be pullin the head. Do any of you guys know where I could purchase just one valve and spring and one pushrod? None of the catologs I have sell singles. I will check with local A.C. dealer after the holiday. Will do a valve job on the ol gal now that im gonna have to pull the head anyhows,but was hoping I wouldnt have to purchase complete set of valves an pushrods. Thanks for all the ideas and suggestions fellas, Hoss
Hossman
07-05-2007 07:21:22
 Re: WD45 comp. follow-up in reply to Hossman, 07-04-2007 08:30:29
Guys, Thanks for the suggestions,I'll check with local A.C.dealer when I get in town this mornin. I'll wait till I actually get the head off before I order anything. Thanks again, Hoss P.S. Old you hold on to your set I wouldnt expect someone to ruin a complete head an valvetrain for one valve,spring an pushrod.Thanks again
Sid
07-04-2007 13:10:04
If you are lucky enough to find a small machine shop. Guys I used to know "rebuilt" a head for me using parts from his discard pile. When he tore down a head he kept all the good parts that could be used again somewere. He helped many a folks that were having a rough time that way.
old
07-04-2007 09:24:53
Guess I've always been lucky since I have freed up a good number of valve and never brake one yet> Agoc should be able to help you with the parts. If not I may also have them but sure would hate to just sell one valve out of the haed I have on hand. Also a good auto parts store or machine shop should be able to get the parts for you also
big jt
07-04-2007 09:15:21
I didn't see the first part of this but I would suggest you tear down the head and see what kind of shape the rest of the valves are in. Might be you need a full set.
Otherwise go to the Agco dealer and see about that route. Another option would be a salvage yard.
jt
