allis b
wkk427
07-03-2007 19:33:13
where do i start trouble shooting the spark at the spark plugs.how do i tell if the mag is working properly.my motor was stuck but i got it freed up and it is turning good now and has plenty of compression.i am not getting a spark at the plugs.it has a new mag that was just installed.it is making a clicking sound when you turn the motor slowly is this normal is there any way to test any of this with a test light thanks alot keith
chalmersbob
07-04-2007 18:20:54
 Re: allis b in reply to wkk427, 07-03-2007 19:33:13
did you time the mag to the engine when you installed the new mag? you could have spark, but not at the right time. Bob
wkk427
07-04-2007 22:44:54
 Re: allis b in reply to chalmersbob, 07-04-2007 18:20:54
when i bought the tractor the mag was already on it and the fellow said that he drove it under the shed when it was parked.i have got the origanal manual and i have been trying to figure out how to make sure it is in time
old
07-05-2007 09:14:05
 Re: allis b in reply to wkk427, 07-04-2007 22:44:54
Well since he drove it in then it was running so timing should not be the problem unless you took the cap off and got the little gear out of place which is easy to do. Most likely the main problem is the points need cleaned or replaced because if they sit for very long the points corrode and will not work if that has happened. If the points aren't good and clean you will not have spark now matter if its timed right or wrong you still will not have spark.
Rod (NH)
07-05-2007 08:47:10
Hi Keith,
Assuming your mag is the common FMJ, this may help as far as checking the timing.
third party image Rod
wkk427
07-05-2007 18:51:37
 Re: allis b in reply to Rod (NH), 07-05-2007 08:47:10
i apreciate all of the info.i have had a lot of trouble because i could not see the timing marks on the flywheel.i finally got number one on tdc using my finger and a welding rod.then i installed the mag cap where the rotor would be lined up with number one.at tdc the metal wheel with the mark was not lined up on center so i could not line the c up with it .i guess it was off when they installed it on the motor.i put it back together and it ran good but i guess if it was timed right it would run even that much better thanks a lot keith kd4qlo
Steve Jelf So KS
07-03-2007 20:23:43
Be sure you have original type copper core plug wires. Are the plugs good? Autolite 295 works well. The magneto clicks, or "snaps", each time it fires. Take out one of the plugs and clamp it to the tractor so it's well grounded, with the wire attached. If the mag is working, you should get a spark when you turn the crank. By the way, if you're hand cranking, only pull up. I forgot that and pushed down on the other side, and now I'm recovering from a broken arm.
wkk427
07-04-2007 04:33:06
 Re: allis b in reply to Steve Jelf So KS, 07-03-2007 20:23:43
how can you tell if it has the copper wires and thanks for reminding me about the hand crank,because now that you mentioned it i remember reading it in the does and donts.i guess god was looking after me cause i probably tried pushing the crank at least a dozen times ,its a good thing it did not fire hu
old
07-04-2007 09:18:47
 Re: allis b in reply to wkk427, 07-04-2007 04:33:06
Look at both ends of the plug wire. On one end or the other you will be able to see the wire if its true wire wire you can see that if its a car type plug wire which will not work on that mag you will see that also. If you need a mag manual just drop me an e-mail and I can send you one. If I remember right it has a trouble shooting guide in the manual also
wkk427
07-04-2007 22:48:11
 Re: allis b in reply to old, 07-04-2007 09:18:47
i would love a copy of anything that you have on this mag.it is new to me but with help i will figure it out one day.
old
07-05-2007 08:38:35
 Re: allis b in reply to wkk427, 07-04-2007 22:48:11
All you have to do is drop me an e-mail unless of course your the one that just did that and if you are then you should have it by now
