WD45 pto housing oil fill.
Don Beyer
07-03-2007 09:10:19
I have a WD45 that leaked around pto housing. Put a new gasket on and was wondering if it gets oil from the hydraulic system or is filled separately from above. There is a plug directly above the pto housing. Just wasn't sure where to fill or does it spill over and fill. Any help is appreciated. Thanks.
Tony Paul
07-03-2007 09:36:57
 Re: WD45 pto housing oil fill. in reply to Don Beyer, 07-03-2007 09:10:19
I own a 1950 Allischalmers model WD and i had same promblem you fill it at plug directly above PTO housing and you use 80-90 WT gear oil and not hydralic oil,i was using hydralic oil and mine always leaked,finally fiqured this out in my orginal owners manual,if you need any more help you can e-mail me directly at [email protected]
