D17 Oil Leak
Chad B. Allis
07-03-2007 05:35:55
I have a '58 D17 with a slight oil leak at the back of the engine where it joins the bell housing. Nothing dramatic, just enought to leave a small puddle on the shed floor. Runs fine otherwise (oil pressure is bit low) - no smoke or other symptoms. Drips more when engine is hot than when it is cold.
Any thoughts or suggestions?
Thanks!
Chad B. Allis
07-03-2007 08:03:24
 Re: D17 Oil Leak in reply to Chad B. Allis, 07-03-2007 05:35:55
If it is the rear main, does that mean taking the engine out to replace the seal? I've never done anything quite that involved.
old
07-03-2007 09:18:13
 Re: D17 Oil Leak in reply to Chad B. Allis, 07-03-2007 08:03:24
If its the rear main yep you have to pull the engine and also take the flywheel off
CliffordPaul
07-03-2007 07:41:59
Actually, I had the same symptoms with my D17 and thought it was the main seal, but upon closer inpection, I had a leaking valve cover gasket; look at the rear of the valve cover and behind and below it - any fresh oil on anything?
old
07-03-2007 07:18:30
Rear main is probalby bad or going bad
