D17 lift arms
CliffordPaul
07-02-2007 18:54:52
The lift arms gradually drop as I run the tractor - in this case brushogging with my new Woods B840 (about 1200 lbs). Every couple minutes I'm having to hit the hydralics to lift the mower back to my desired cutting height. Where do I start looking for the problem? By the way, thank you guys for your help in getting to the bottom of my coil problem. Thanks CP
TexasAllis
07-03-2007 05:20:16
 Re: D17 lift arms in reply to CliffordPaul, 07-02-2007 18:54:52
CP,
If you have a series I, II, Or III the lift will creep down slowly. If you have a transport valve that will help keep the lift from dropping. Another problem may be the internal lift cylinder. The cylinder could be leaking and or the supply hose. Not too hard to fix but takes a little time to get to it. The series IV was not as prone to that problem. I tie a chain to the bottom arms at the level I want the cutter to run so it always stay the same height and have had no problems.
