WD45 compression
Hossman
07-02-2007 14:56:20
Fellas, I asked some questions a day or so back on an ol'45 I had looked at and after gettin it I'm tryin to figure out the no fire on what i thought was two of the cylinders. Well I did compression tests this mornin and got 110 on cyl.1 and nothin on cyl.2 cyl.3 had 110 and cyl.4 had 95. What my question is... with no compression reading at all on the second cyl. would that more likely be a valve hung up or the rings on that cyl.?I was under the impression that rings stuck would still give some sort of readin, an a stuck valve would give no readin at all. Im plannin on pullin the hood an then valve cover tommorow an takin a look see but thought id get some of the ol veterans opinions first. "Old if your out there wade on in" As always thanks guys, Hoss
Texas Denny
07-02-2007 20:40:52
 Re: WD45 compression in reply to Hossman, 07-02-2007 14:56:20
Since it is only one cylinder and the other three are in usable range, I'd agree - sounds like a valve problem. At least, that's the first thing that I would check. It's also the easiest. Unfortunately, a mis-adjustment of the valves is not too terribly common (hopelessly burned or cruded valves are more likely). So you might still have to pull the head. If you have the equipment, I think Greg's plan is great.
Greg_Ky
07-02-2007 15:47:19
Hoss,
Take your distributor cap off and turn the engine over until the rotor is pointing at #2 cyl. put her in high gear and lock the brakes, then take your air hose and hook it up to your compression tester adapter and put 100 psi. of air into that cylinder and where ever the air come out that is where the problem is (intake valve, exhaust valve, crankcase = rings etc.)
