CA hydraulics
John DeHoff
07-02-2007 14:08:38
Changed hydraulic fluid in my 1953 CA and cannot get the hydraulic cylinder to go in or out. (HELP) Thanks in advance.
Big Hunter
07-03-2007 02:14:57
 Re: CA hydraulics in reply to John DeHoff, 07-02-2007 14:08:38
it may have something to do with the linkage...get a manual and check the linkage
backcountryxtreme@windstr
07-03-2007 05:35:35
 Re: CA hydraulics in reply to Big Hunter, 07-03-2007 02:14:57
Thanks BIG HUNTER, Information was a great help. Thanks for responding.
Texas Denny
07-02-2007 20:35:09
What kind of fluid did you take out and what did you put in? The original spec was 30W non- detergent oil. I've heard a few people on the board say they have been successful in switching to hydraulic fluid which is around 20W. If your system is worn considerably, going from a high viscosity fluid to a low viscosity fluid might reduce the lifting power because of leakage preventing pressure buildup. But even so, there should be some response. The PTO must be running to get the hydraulics to function - easy to forget.
John DeHoff
07-03-2007 05:48:53
 Re: CA hydraulics in reply to Texas Denny, 07-02-2007 20:35:09
Thanks TEXAS DENNY, I did forget to have the PTO engaged. Everything is working now. Thanks again for the help.
