Venith Carb.
Harry J. Case
07-01-2007 21:46:28
Hey Guys Does anyone know the specs for adjusting the float level for a 0-7178, 7078 Zenith carb. I sent mine in to the folks at Booneville Mo. to be rebuilt and it came back all shiney on the outside but I have the same problem I had before I shipped it off to be rebuilt. The engine will start up ok but starve for fuel in less than a minute and die, there is good fuel flow to the carb so I'm thinking it must be a float level problem. Any help would be appreciated, Harry Case,Allis,Moline nut
Harry J. Case
07-05-2007 20:23:40
 Re: Venith Carb. in reply to Harry J. Case, 07-01-2007 21:46:28
Hey Bob You are absolutely right, also Mike Hoolihan sent me a tip on how to check the fuel level I found a sticky float valve, hosed it out with WD40 and I now have gas gushing into the bowel instead of dripping! Thanks,Harry
Bob
07-01-2007 23:03:59
Since it runs OK for a while, then falters, you can bet it's a fuel flow problem NOT a float level problem.
Take out the bowl drain plug, and see how much gas continues to flow after the initial fast flow as the bowl drains.
