WD 45 question
Hossman
06-29-2007 16:28:13
Fellas, am lookin at a 56'wd45 to buy of a feller and this ol gal has been settin for quite a while outside. The stack has been covered and everything looks pretty good. Well we threw some fresh fuel into it and she fired right up. The ol gal seems to have a miss and upon inspectin the plugs the first an second cylinders appear to be awful wet with gas and I held these plugs to ground and there gettin what looks to be pretty good spark,the 3rd and 4th cylinders seem to be alot dryer,and I was wonderin what would cause cyl.1&2 to be so "wet" while 3 and 4 appear normal? Also while the tractor was settin there runnin I pulled the 1st cyl. plug wire at the plug and nothin changed at all in the way the ol gal was runnin I then with that plug wire off pulled the wire at the plug on the no.2 cyl. and also nothin changed in how the ol girl ran.Is this normal? Shouldnt the motor falter a little or somthin when these wires are pulled? Or is this tellin me the 1st an 2nd cyl aint firin? For what its worth the points seemed ok I checked gap and it was correct as was spark plug gap. Any suggestions would be great. Thanks alot,Hoss
Hossman
07-02-2007 06:47:48
 Re: WD 45 question in reply to Hossman, 06-29-2007 16:28:13
Fellas, as always thanks alot for the suggestions, will attempt to figuire this one out. Hoss
Jack as
06-30-2007 03:34:06
Could be the wires are switch but most likely stuck valves. Take the cover off and have a look. See if the valves return to seat when you crank it over using the hand crank. I have just oiled up the stuck valves and tapped with a hammer and pried with a bar until loose enough to run. I'm not sure why some don't like champion plugs but I've never had real problems running J8's in my WD or N9's in the D17. NGK and AC are the plugs that have given me problems in the past. Used to pull my tracors and had brand new NGK plugs that lasted about a month. Also have had good luck with Autolites.
old
06-29-2007 19:32:02
Well if it has sat very long then it could be a few problems. Stuck rings or valves. Bad plug wires and or bad plugs. One like that is what I get most of the time and playing with them I get them to work just fine. It may even have a bad cap or rotor. Theres so many small things that can cause that its not funny. Plugs, valves, rings stuck, bad cap or rotoe, bad distubutor, bad plug wires, or even a blown head gasket.
Texas Denny
06-29-2007 17:47:09
Also, be certain that the plug wires are correctly hooked up. The order is 1243 with 1 in front. I once worked on a friend's 9N Ford. Every wire was on the wrong plug but it still ran on two cyylinders. If you can't do compression, I'd do a new set of AC, or Autolite plugs (no Champions - WD's and WD-45's don't run good with Champion). Good looking plugs don't always work.
Also, you could pull all plugs and just put your finger in the plug hole as you turn the engine over with the starter. If you have no compression on a cylinder, you'll be able to identify it. You'll be surprised at how low compression can be and still make the engine will run.
While you are checking compression on #1, check to see that the rotor is aligned to the plug wire for #1 cylinder when you get the compression stroke.
John (C-IL)
06-29-2007 16:54:06
Generally you also need compression to fire. I would suspect that you may have one or valves stuck. Even though you have spark at the wire you could have bad spark plugs in those cylinders. For a down and dirty test try switching the plugs between cylinders. It would also be worthwhile to do a compression test or at the very least pull off the valve cover and check the valve action.
There is a reason that tractor was parked and you may have discovered it.
